IF Formula for naming a field
1013 6
Leah_Relish
Hello Community!
I am struggling with writing a formula for naming the main field in a table.
I would like the formula to name the field {Company} if the field {Company} is not blank and name the field {Last Name} - {First Name} if the {Company} field is blank.
I just can’t seem to get it right. Can anyone help?
6 Replies 6
Hi Leah, could you try the following?
  {Company},
  {Company},
 {Last Name} & " - " & {First Name}
Edit: Fixed the error kuovonne pointed out below!
I think you mean
Otherwise you are trying to do math with names.
Formulas can set cell values. Formulas cannot change the name of a field (the column heading).
Hahahha now you’ve got me thinking about how I would deduct a first name from a last name
YES! You are amazing. I was totally over complicating it.
Thank you :slightly_smiling_face:
:rofl: too funny - and good point!
