IF FORMULA issues
677 2
Scott_Gardner1
7 - App Architect
7 - App Architect
Question:
Here is my formula:
IF(AND({ITEM DESCRIPTION}),{ITEM DESCRIPTION} & " - " & {TASK TYPE} & " " & {TASK NAME} ,BLANK())
I need a - if the task name is filled in the drop down field to separate from the task type, but if the task name is blank, I don’t want the - at the end of the task type - make sense?
ITEM DESCRIPTION - TASK TYPE - TASK NAME
But what I don’t want is ITEM DESCRIPTION - TASK TYPE - , when the task name is blank, It would read ITEM DESCRIPTION - TASK TYPE
Thank you!
Hey @Scott_Gardner1,
Give this formula a try:
    AND(
        {ITEM DESCRIPTION},
        {TASK TYPE},
        NOT(
            {TASK NAME}
    {ITEM DESCRIPTION} & " - " & {TASK TYPE},
        AND(
            {ITEM DESCRIPTION},
            {TASK TYPE},
            {TASK NAME}
        {ITEM DESCRIPTION} & " - " & {TASK TYPE} & " - " & {TASK NAME}
There are many ways to do this. Here is my style.
  {ITEM DESCRIPTION},
  CONCATENATE(
    {ITEM DESCRIPTION},
    IF( {TASK TYPE}, " - " & {TASK TYPE}),
    IF( {TASK NAME}, " - " & {TASK NAME})
