Hello all,
I would like to use an If formula:
Everything before a certain date should be “True”, everything after “False”.
When I write it like this, it doesn’t work:
IF(InvoiceDate<3/8/2021,1,2) (InvoiceDate is a Field in Type “Date” with Format “European”).
Do you have any idea and could you help me please? Thank you very much!
Hi @Sebastian_Apel
Airtable doesn’t recognise the “3/8/2021” as a date witch which it can work. You have to convert it into a date type using DATETIME_PARSE()
This should work:
IF(InvoiceDate<DATETIME_PARSE("03-08-2021", "DD-MM-YYYY"), 1, 2)
Hi @Databaser , thanks for your quick and good answer!
That has worked before. Now I immediately encountered another problem: I want to connect the IF function with another IF function.
If I do this as described below, the result is always “0”, even if the amount should be different.
Could you maybe help me again please? Thank you very much!
IF(InvoiceDate<DATETIME_PARSE(“03-08-2021”, “DD-MM-YYYY”), (IF((SUM(PaymentAmount,{CurrencyDifference})/{InvoiceAmount})=1,0,{InvoiceAmount}-PaymentAmount)), 0)
Sebastian_Apel:
Try
IF(InvoiceDate<DATETIME_PARSE(“03-08-2021”, “DD-MM-YYYY”), IF(SUM(PaymentAmount,{CurrencyDifference})/{InvoiceAmount}=1,0,{InvoiceAmount}-PaymentAmount))
Hey @Databaser .
This working very well. Thank you so much!
Glad I could help! Would yo mind marking my comment as the solution to your question? This helps others who may be searching with a similar question. Thanks!
system
closed
August 7, 2021, 3:51pm
#7
