Dear airtable community, i am looking for a function that:
if a certain cell is modified, i get a value in a ‘last modified time’ field. after getting that, i want to know the work day difference between my ‘last modified time’ field and a ‘order date’ field. if the mentioned cell at first hasn’t been modified yet, i won’t get an return for the ‘last modified time’ field and so i want to have a blanc for the difference in work days.
i’m aware of the fact that the point of formulating the conditon, isn’t fullfilled, but i have no idea what else to put there. if there’s an easier way of fullfilling my need than the if function, please. let me know
You can also drop the BLANK() function on the end. Airtable will automatically leave the field empty if the condition fails. That reduces your formula to just this:
As for the condition itself, your formula works just fine. Putting a field reference alone in that space will return True if the field contains anything, and False if it’s empty. (Number fields are the only type that break this rule because a 0 in a number field makes it not empty, but 0 is also equivalent to False.)
