IF Or formula not working
833 1
David_Ramos
I want to know what is the proper formula to use this…
IF(Checkincount= 99, TRUE(), FALSE())
I’d like to have an or option meaning
IF(Checkincount= 99, TRUE(), FALSE()), OR IF(Checkincount= 199, TRUE(), FALSE()), OR IF(Checkincount= 299, TRUE(), FALSE())
I can’t seem to find the right formula to use the OR
Meaning, I want it to show if Checkincount is 99 or 199 or 299 etc…
Hope that makes sense.
Thanks
If what you really want is for this field to show “True”, or 1 only when {Checkincount} is equal to exactly 99, 199, 299, etc, and show “False”, or 0 otherwise, you could probably do that a little more efficiently like this:
   RIGHT(
      {Checkincount}&"",
      2
   ) = "99",
   TRUE(),
   FALSE()
