If "QTY Used in Part" Equals 4, 550, or 1000 Then "correct" if not then "incorrect"
814 3
Kristin_Turner
Not sure how to properly write this out in a formula.
I’ve got it working with this one formula: IF({QTY Used in Part}=1000,“ :white_check_mark: Good :white_check_mark: ”,“ :red_circle: Incorrect :red_circle: ”)
I’ve tried just using a bunch of IF statements, I’ve tried to make AND/OR work to no avail (probably not doing it right), I’ve read about Switch but am unsure of how to make it work for my needs - I have no idea where to go from here.
Please help.
3 Replies 3
The forum software won’t let me show you this with emojis, but here’s the structure of the formula:
SWITCH(
{QTY Used in Part},
4,"Good",
550,"Good",
1000,"Good",
"Incorrect"
You are my hero! ❤️ Thank you so much! I was getting SO frustrated not understanding.
You’re welcome! Glad to be your superhero this morning! :man_superhero:
