If you’re using the Google Docs automation, but discovered you need more customization and features, check out On2Air Automated Documents in our Actions extension.
You can use Google Docs, Google Sheets, or Google Slides to create any kind of document.
You can use the power of Google to customize your document and it will export as a PDF back into an Attachment field.
Here’s a full breakdown of On2Air Documents vs Airtable Google Docs
