Ignore case for filterByFormula
#1
Hi everyone!
I’m having a problem where matching a record using filterByFormula (through curl) is behaving in a case-sensitive way. I need it to ignore the case.
The request is constructed like this (Angular):
return $http({
  medthod: 'GET',
  url: api.BASE_URL + '/Members' + "?filterByFormula=(Email='" + email + "')",
  headers: {
    'Content-type': 'application/json',
    'Authorization': api.KEY
api.BASE_URL and api.KEY are fetched from a config file and email is passed into the function. The resulting request URL is this:
<REMOVED BASE URL>/Members?filterByFormula=(Email=%27passed@email.com%27)
The problem is that this appears to ONLY find a record with that exact string, where I would like it ignore the case.
A possible workaround would be to force the email input field (the string being passed into the request) to be lowercase, but I would rather if this was fixed by ignoring the case.
I have looked through the API documentation, this forum and searched Google for anyone with the same problem but didn’t find anything useful.
Thank you for any help on this!
#2
Hi!
I think the following should work…
filterByFormula=(LOWER(Email)=%27passed@email.com%27)
Or additionally add another ‘lower’ around the email string you pass…
#3
Thanks for that suggestion! Hadn’t thought of that. While it doesn’t answer the question on ignoring the case, it could be used to improve the possible workaround.
