Hi, i have an issue with a zap on zapier here is the message : "The app returned “You are not permitted to perform this operation because the field or table has been configured to limit who can perform this operation”.
this is a message from Airtable. I’m the owner of my workspace, i’ve put permissions on “editors and up”, so i don’t understand how to fix the issue
Have you tried removing the permissions altogether?
how to do it ? i’m the only one who use the database by the way
It will either be an option on the field, I believe. Have you checked your fields here
Yes i’ve checked everything is on “editors and up”. I don’t know where the issue is. There is only one field who shows a message like this (see the photo below), i don’t know if it’s corelated to the issue.
