Importing Fonts
Topic Labels: Extensions
1421 3
Gerard_Goosen
Can you import your personal fonts? Or is there a way to use specific font types? (Brand Specific)
Thanks
3 Replies 3
Amanda_Nguyen
@Gerard_Goosen did you find a way to do this?
mpourmystere
Any news on if this is possible?
Mimmuli
Seems like it can be tricky to have other fonts than CSS Web Safe fonts. Something that kind of worked for me:
<!DOCTYPE html>
<h1 style="font-family:Poppins, Helvetica, sans-serif;"> Insert your heading here</h1> <p> This is the paragraph for other text.</p>
CSS Web Safe Fonts that should work: https://www.w3schools.com/cssref/css_websafe_fonts.php. I wanted to use Poppins font and it seems to only work in Outlook desktop app, so that is why I have the Helvetica as a back up font.
