Improper formatting URL when using "filterByFormula" with Dexter bot
Topic Labels: API
1414 3
Michael_Feola
I am currently trying to pass in an option for the airtable API which is going through Dexter. The following POST method works:
$ POST https://api.airtable.com/v0/<bot airtable_base>/Profile/ {"headers": {"Authorization": "Bearer <bot airtable_api_key>", "Content-Type": "application/json"},"body": {"fields": {"FormalName": "<get name>","Address": "<get address>"}}}
but I can’t seem to get this GET command to work
$ GET https://api.airtable.com/v0/<bot airtable_base>/Profile/ {"headers": {"Authorization": "Bearer <bot airtable_api_key>", "Content-Type": "application/json"},"body": {"filterByFormula": {(FIND("FormalName","My Name"))}}
Anyone get this to work?
3 Replies 3
openside
10 - Mercury
10 - Mercury
your filterByFormula is not valid json. try:
{"filterByFormula": "FIND('FormalName','My Name')"}
Michael_Feola
Thank you!
This was the fixed version
$ GET https://api.airtable.com/v0/<bot airtable_base>/Profile/ {"headers": {"Authorization": "Bearer <bot airtable_api_key>"},"body": {"filterByFormula": "({FormalName} = 'My Name')"}}
Hey Michael! Did you figure out how to call on the API’s response here inside Dexter? If so, how did you do it? The below isn’t returning anything for me.
${{records}}
