Integration from Filemaker Pro to Airtable
Topic Labels: Integrations
1346 2
John_Turquoise
I am trying to have Filemaker Pro send all records to a database in one of my Airtable bases, using a rest. Here is my filemaker script, with key/api blanked.
Send to Airtable
#Send a foundset of records to AirTable
Go to Record/Request/Page
[ First ]
#Walk through the records and create a data package of records
Loop
Set Variable [ $Names; Value:"$Names & Case( not IsEmpty($Names) ; “,”) & Airtable::cJson" ]
[ Next; Exit after last ]
End Loop
#Put the required wrapper around the record data and URL endpoint
Set Variable [ $URL; Value:“https://api.airtable.com/v0/______/Filemaker” ]
Set Variable [ $Action; Value:"-X Post" ]
Set Variable [ $Authenticate; Value:" -H “Authorization: Bearer _______\”]
Set Variable [ $ContentType; Value:” -H “Content-Type: application/json”]
Set Variable [ $Names; Value:"{“records”: [ " & $Names & " ]}" ]
Set Variable [ $Data; Value:" -d @$Names" ]
#Send the records to AirTable
Insert from URL [ $Response; cURL options: $Action & $Authenticate & $ContentType & $Data ]
[ Select; Verify SSL Certificates ]
Exit Script [ Result: True ]
andyknas
John, Were you getting errors with your POST? Always add these curl options too. Curl debug is the best so you can see what you're sending and the actual response, including headers.
"--show-error " & "--dump-header $$header " & "--trace-ascii $$curl_debug "
kdburns
@John_Turquoise I know this is an old post and I was curious if you were able to get this to work.
