Integromat Help
Topic Labels: ImportingExporting
512 0
Kevin_Austin
I’m using Integromat to look at the Airtable Record Last Modified Time Field as the trigger, then it goes to GMAPS and gets some mileages and comes back and updates the record. Does anyone know how to keep it from recalculating all the mileages and updating all the records, only the ones that have been modified? I have the scenario set to 'Choose Where To Start ’ “From Now On” Its running up a lot of “Operations” in Integromat.
0 Replies 0
