Integromat search against a formula field problems
1987 5
DTL
Hello all,
I’m having problems with the following search formula in integromat:
{field_name}=“value”
In this particular case, {field_name} is a formula field. I’ve checked the values, and the naming, and everything is correct. So I can only surmise that you can’t run a search against a formula field?
Can anyone help?
Drew
5 Replies 5
M_k
11 - Venus
11 - Venus
Hi @DTL
Check to make sure that the quotes are straight, up and down (pretty quotes.)
I have an example:
Hope this helps.
Mary Kay
DTL
So this doesn’t work. I just tested it hardcoding the value in and that didn’t work either.
DTL
Figured it out! thx @M_k
Hi @DTL
How did you figure it out?
So that I know, if there are similar posts.
Thank you,
Mary K
DTL
Well, I’m not entirely sure what the problem was. But, I ended up using SEARCH instead of the traditional way.
