Interface: Cannot use formula result in Number Element
1512 3
Gavin_Andrews
I am using a formula to subtract one weight (ungraded weight) from another (graded weight). The formula in the dashboard is working fine to make Unaccounted Weight:
However, I cannot choose Unaccounted Weight in Interface Designer. I want it to appear just as a number element.
Does anyone know what I’m doing wrong?
It is in the same table. It only shows fields that are linked records. No idea why.
However, I was able to make it work by using field elements.
3 Replies 3
It looks like your number element is connected to “Grading Lots”. Is your {Unaccounted Weight} in a different table?
Have a good time, my beautiful friend. With you is Abu Wadih from Syria. Can we be friends?
