Inventory Management - Need API developer for QR scanner project
549 1
Chrissy_Freeman
Looking for a developer to help with API project. We have a functioning database, all structures are rocking but need to get a certain scan view that we can’t accomplish with Airtable/mini extensions alone. Looking for someone to help with an API project to display records, scan from one column to another in a “bag” or “order” scenario. Basically… confirming they are in the right order/bag. Accomplishing this in airtable with QR scanners, but need scalable front-end interface that employees can use.
Trish_c
Surely, we can assist you on your requirements.
PM sent, please check.
Regards,
Trish
