Invoice going up
how can i make a field of invoices thats starts from 1000 and goes up?
like
1001
1002
1003?
im kinda stuck, much appriciated! :smiley:
Hi @idan_bernard - have a field that is an autonumber:
54
Then make your primary field a formula and use:
1000 + AutoID
You can hide the AutoID field if you don’t want to see that.
Worth noting that if you delete a record, you also delete the autonumber associated with it, so that won’t then be available:
JB
thank you so much jonathan, is there any chance i can ask you a couple Airtable questions in email or whatsapp?
i really need to do a small task for a job application it will be so much appriciated.
thank you so much.
