IOS 11 "copy phone number? issue?
#1
In IOS messages, there is an option to “long click” on a phone number and a context menu comes up that allows one to copy the phone number. When I do this then attempt to paste the phone number into my Airtable field, the phone number does not paste properly, (gibberish characters are added to the number).It seems to work OK in every other app. Is it an Airtable issue?
#2
Have you pasted that text into another non-Apple app? Does it show up as just a phone number or does it also have additional text?
Also, as a general rule, this forum is not Airtable support. The best thing to do would be to contact support@airtable.com or go directly through the Airtable app itself.
#3
Thanks for reporting this issue — I’ve gone ahead and filed a bug report so our team can investigate :slight_smile:
