Is it possible to create a form view in a synced base?
Topic Labels: Sync
614 1
Help_to_Help
Hi!
I have created a sync between two bases in Airtable. In the destination base, I want to create a form view with questions that should become new records in the synced table, but I can’t find the “form view” option. Is it possible to create a form view in a synced table? The new records from the form submissions should only stay in the destination base.
Thank you in advance,
Clara
No, that is not possible. The form must be created from the source table.
