Is it possible to rename a view?
1343 1
Amanda_Hickman
Is there a way to rename or delete views? I can’t see either!
Thanks,
Amanda
To rename a view, double-click on the view name in the view bar:
rename
To delete a view, click on the ellipsis button (…) in the view bar, then select Delete view from the dropdown:
