Is it possible to upload attachments?
#22
I’ve done a ton of work with cloudinary API and used their widget. It’s very well done and works well. I’ve also pushed attachments to Airtable using the API (as a url). So I have no doubt its possible on both sides. You would just need to build it into your application. If you provide more details on your specific scenario I can give more specifics on how to approach it. Feel free to ping me at dan@openside.com
#23
Thanks, I will shoot you an email.
#24
I want to thank you so much Dan for suggesting cloudinary. I have got this up and running beautifully and the images are uploading to Airtable. I will be writing up a blog post with the code to help others and will post the link here for anyone who needs help.
#25
As promised, my write up of my solution.
#26
Looks great Chinara, good job! You should post this to the Show & Tell forum as well.
Dan @ Openside
#27
Ok will do. Hope they don’t mind the duplication.
#28
Thank you Chinara and +1 for adding this functionality to the API!!
