Is my syntax wrong in IF formula for Lookup column?
705 1
Emma_Garwood
Hi there Airtable community!
I’m having trouble with an IF statement. I have a lookup column with two values, Turned or H/L. If the value is Turned, I want my formula to add the values in each of the shoe sizes listed. I’m getting an ERROR every time I try it though. Is it because the value (H/L) is a lookup value? The formula saves correctly, but the resulting value is #ERROR!
Screenshot attached too…
thanks for your help :slightly_smiling_face:
SEARCH(“H/L”, {Toe Puff}),
SUM({2},{2.5},{3},{3.5},{4},{4.5},{5},{5.5},{6},{6.5},{7},{7.5},{8},{8.5},{9},{9.5},{10},{10.5},{11},{11.5},{12},{12.5},{13},{14})
Screenshot 2021-06-11 at 11.26.15
Emma_Garwood
Ah… thanks to @AlliAlosa on this thread
I added ARRAYJOIN and the searching of the lookup field worked. Nice!
Emma_Garwood
