Hi there,
I have created a table I would like to send to 10 to 20 different people. There is one column that has a checkmark option - this is the only option I would like them to edit (check or leave empty). There are more than 200 rows so it’ll be difficult to simply send out a google forms and concatenate inputs into a table.
I was wondering if anyone would like to suggest a clean way to collect this data without having to create 10-20 different tables to send to each person?
Thank you very much for your time!
Warm regards,
Michelle
I cannot quite picture what you are describing, but you might want to be aware of some of Airtable’s limitations that may make it hard to do what you want.
Only Airtable collaborators can directly edit data in a table. If you use Airtable’s method of sharing a table, the table is view only.
An Airtable form can collect data from anyone who fills out the web form. However, the result always creates a new record in a single table–one new row with a single value for each column.
Apologies if I’ve misunderstood your use case.
Thanks for your help Kuovonne!
