Hello ! I am deactivating quite manually and inefficiently many forms that have been created on a base by clicking on each one of them and desabling their shared view link (share form menu)
Is there a way do it in a faster or mass deactivate forms on a base ?
if you just need to break the links and you do not need those links back or the audit history of the record or run history of any automations you can just duplicate the base and delete the old one. duplicating a base changes ALL links tho. ALL LINKS
Hi @Rebecca_Elam , thanks for your quick relevent reply. Yep , unfortunately I need to keep this base, I cannot use a duplicate one. Otherwise your solution would have worked , thanks
