Is there a way to find out how many records your base has used?
6982 2
Tyler_Key
Was just wondering if there was a way to see how many records each base is using?
For example to check if you are near your limit of 1,200 / 5,000 / 50,000 records?
Thanks.
dave_brand
Hey Tyler,
yes! Check your Workspace Settings --> Usage
Stacey_Cummings
Yes, you can see it on your workspace settings, but it is not real time. If you remove or add records to base you have to wait a day for that number to update. Since we are on a price structure based on number of records, this should be real time.
Hope someone replies to this with another way to check number of records.
Stacey
