Is there a way to 'patch' a record?
Topic Labels: API
3052 2
Kareem_Sultan
If I PUT a record without including every field, those missing fields are emptied losing the data that they held.
Is there a way to PATCH a record by only supplying the modified fields ensuring the rest are untouched?
Nathan_Cain
Yes. Have a look at the api documentation for your base. For each table there is a section called “Update a record”. This describes how to do a curl PATCH.
Kareem_Sultan
Perfect! Works like a charm. Thanks.
