Is there a way to print 2 columns - one side text, the other side images?
Topic Labels: Views
1521 1
Vincent_Tang
is there a way to do this?
Basically, I want a base with only 1 table
Inside the table there’s 2 columns. Per row, this is what the values have:
  • 1 image attachment
  • Text associated with image
Could I print out something with very large images on one side, and text on the other side associated with it?
Like this mockup I made in Microsoft OneNote:
I didn’t find anything like this in the print options, not sure if this is a supported feature or not
mzah8
I don’t think this is possible? The closest way is to create a Gallery view. In the print view, the larger images are shown, but the the text appears below the images.
