Is there a way to show "My Records" using the Collaborator fields
474 1
Ruchika_Abbi1
7 - App Architect
7 - App Architect
I would like the different Collaborators to be able to have a view where they see only their records when they login to Airtable.
Currently the only way to do this would be to create a view for each user with a filter on Collaborator field.
Or is there a better way to do this, say filter for Collaborator to be the “Signed In User”
Ruchika
No, you have to do it the way you’re currently doing it.
That’s a good idea, though — you should send it as a feature request to support@airtable.com.
