Issue with creating embedded view
947 1
Jacob_Turley
Hey all!
I’m currently just messing around with airtable and I am having some issues embedding a view…
As you can see, when I embed that view into confluence, there is a giant gap. Also, there are technically more fields it can display… Am I doing something wrong? I understand I can just reduce the width, but why doesn’t it want to display other fields when it has room?
Jacob_Turley
Also, when restricting the width I get this irregular placement:
Any way to fix that, or is that just the way it is?
