Issue with stacking in Kanban view
Topic Labels: Views
857 1
neovospoon
Hi all,
First-time post here! so a big hello! This is potentially a newbie question…
I’m trying to stack my based column in the Kanban view but the option isn’t appearing?
Based is a multiple select list of local authorities
I did screenshot but it’s not letting me post them…
Any help be much appreciated
Thanks
Jeremy_Oglesby
14 - Jupiter
14 - Jupiter
Kanban views can only be created on the basis of Single Select fields, not Multiple Select fields. Once you see how the kanban view works, you’ll understand why that’s the case.
You might try using the “Group by” menu to group on your Multiple Select field in a grid view as a sort of workaround for your use case… I find that to be cumbersome, though.
Jeremy_Oglesby
14 - Jupiter
14 - Jupiter
