Jira Labels Field- Airtable Create a Task Automation
Topic Labels: Automations
486 1
Taylor_Garrity
I am trying to create an issue that is automated from a trigger in Airtable then creates a task in Jira. It is working other then it is not bringing over the labels in Airtable into Jira.
I have tried single select, multiselect, text field. I made sure it is a label that exists in Jira and matches exactly in Airtable.
Any advice on how to get labels to populate from Airtable in the Jira task when it is created?
Could you provide some screenshots of your automation action?
