Junction records automation
739 1
Jim_Bain
I need help writing the following script:
Tables:
  • Classes
  • Students
  • Grades (junction table)
Each time an Enrollment form creates a new record in the Classes table, the script creates a record for each Student in the Grades table. Grades table is a junction table linking Classes and Students tables.
I know there are several community scripts regarding junction tables but I need one that works from just one Class record at a time.
Jim_Bain
I finally figured it out:
//Generate Grade record for each Student registered in user-selected Class
let classesT = base.getTable('Class');
let eachClass = await input.recordAsync ('Select the Class', classesT);
let gradesT = base.getTable('Grades');
// for each student in the students array
for (let student of eachClass.getCellValue('Students')) {
    // create a grade record
    await gradesT.createRecordAsync({
        'Class': [{id: eachClass.id}],
        'Student': [{id: student.id}]
Jim_Bain
