Kanban grouping using link fields
#1
Is there any way to use link fields for kanban stacks. It appears that only single select fields can be used, but I would like to use a grouping field that is a lookup to another table. As a simple example, I have a location field, which is a lookup field to another table, defining locations. I would like to use that as the grouping field in a kanban view. It looks as though the only option I have currently is to duplicate the field with a single select field, and then find a way to keep both in sync?
Many thanks for any help
Neil
Kanban Structured by lookup
Single select field that is linked to a record?
#2
I’d like the same functionality that Neil is asking for
#3
I’d also like that to be possible.
#4
I’d also like to have that functionality.
#5
Also looking for this feature.
#6
#7
#8
This would be great. I know kanban is about moving work along a visual pipeline. But the format has more potential. I was hoping to create a Kanban view using web pages as the stacks. I could then see and arrange content sections by page stack. It can be don by grouping, but the line up of pages and content was an appealing concept.
#9
I’m in content publishing, and we regularly have to keep track of which content has been published, etc. across several different clients and account managers. So naturally I have to use different tables for each client as each client has a different and unique publishing schedule.
This feature would be a game-changer for me as well, as I’ve been trying to find workarounds for this for the last several hours. Tried to duplicate a column, and sync columns across two tables, but couldn’t find a solution. Using linked fields for kanban stacks would be a godsend as it’ll help me bring sync all the content across several tables
#10
Another vote for this feature. I wouldn’t mind if dragging records isn’t supported for field types different from single select.
#11
Another vote for this feature too!
Would allow calculated fields once an observation meets a criteria to be automatically moved along.
#12
Please can we have this
#13
I also really want this to be a thing. I have a to-do list, which has a link field to a projects list, and I’d like to group the todo list by project
#14
+1
Please add this feature!
#15
I’m in the exact same situation…otherwise I can view from the project side, showing the tasks in a card, but only a few and not in any ‘actionable’ way (checkbox, etc.)
#16
Another vote for this feature. Please keep the drag & drop functionality!
#17
Is it possible to create a single select field and get the options from another table?
I am trying to view a table in Kanban mode and get the cards arranged by a particular field … but that data is currently linked to another table and not a single select field.
#18
I wonder if this would be better solved by allowing linked records to be the basis of a Kanban view as well as single selects, rather than creating a single-select mode for linked records.
#19
Yes, definitely. I was just hoping for a workaround.
Airtable is incredibly powerful and yet still has some huge weak spots that could turn people away.
Kanban is a great feature but needs to be more flexible in order to really leverage Airtable´s data handling possibilities.
#20
I have the same problem. I would change to airtable if it had this simple feature.
