KanBan help needed
Topic Labels: Views
1122 1
Terri_Bose
I am trying to create a kanban view with my existing collaborators as the stack field. The only available option is to create a new record for collaborators or select one of the other multi select fields.
I had it set up properly but that view is now showing a different stacked field and I can’t revert. Probably one of my collaborators inadvertently changed something. I’m assuming there is a way to lock this so it doesn’t happened again?
Anyone know how to get my original view back? Undoing didn’t work.
Mike_McLaughlin
8 - Airtable Astronomer
Did you take a snapshot of your base? even on free, that should go back 2 weeks. I believe the undo will only work for actions your account has done.
going forward, you may want to restrict the other users (to ‘editor’ status) to only be able to edit records and not base structure.
