Keyboard shortcut for audio playback in Attachment field
1059 4
Julia_Kulgavchu
Attachment field type has a nice preview element for audio files. They can be played by clicking on the ‘play’ icon. Is there a keyboard shortcut for playing those file? I didn’t find it in the official list.
4 Replies 4
Does the space bar work? If not, same answer as your other post here:
Space bar doesn’t do that. It expands the record. From an expanded record I need to mouse-click to play the file.
Shift+Space expands the cell, but then again nothing to play.
Enter opens a window ‘Select a file to upload’.
This question is indeed related to the other one that you replied to, about custom shortcuts (Custom keyboard shortcuts for quick actions: how to make?). For audio playback specifically I was hoping to discover native functionality, because this is about using a single standard UI element (audio playback inside Attachment field type). For the other question about custom shortcuts, no such hopes :slightly_smiling_face:
Best you can do is add it as a feature request in the #show-and-tell:product-suggestions category.
Keyboard Maestro might be able to help, not sure. Keyboard Maestro can perform mouse clicks.
Thank you, I’ll look into Keyboard Maestro and its alternatives. And will add a feature request, why not :slightly_smiling_face:
