Link to other base
#190
If we look at Google Sheets, each sheet has its own permission - and you can link to any sheet imaginable - so long as there’s read access.
This could open up the a WORLD of collaboration between Airtable users…
e.g. if somebody shares a base with country codes, regions etc. or population stats that only need to be updated in a central place.
My use case for sharing, would be that I create a base for all my customers to reference, so they don’t need to do the work themselves - read only of course.
#191
YES that would be awesome! I will see that it helps that I discovered that I can use “dumb” links – copying the link to a record and pasting it into a URL record field in another base will take me back to that record when clicked. BUT I don’t want to have to go to the base I want to link to, find and open the record, copy the link, return to the new base, find the record I was working on and paste. Yikes, that’s not really scalable in a workflow.
I would use this to create an effective master task list for myself. I store each individual client’s project in it’s own base, then I have a base for my company. I want my company base to hold my master task list across all bases, where I can link to tasks in each individual base. It’s the only way I’ve thought of to have a master task list that gives me a big picture of everything I need to do in a given day. Otherwise, I have to visit 6+ bases and manually make a new list of tasks just to see what’s assigned to me that needs to get done in a given day.
#192
Hi @Lauren_Perfors
While I agree with everyone that links between bases would be very useful, I may have a couple of suggestions which may help you…
  1. Airtable link directly to Slack and you could have your bases creating posts in slack channels - these are great because the posts have direct links to the records.
  2. It would be possible to use Zapier to create the tasks in your master base automatically - including populating a field with the link to the record concerned.
  3. Have you considered having all your data for all clients in one base - and use filtered views where needed to look at information per client? This would obviously not work if you need to share the base with the client. This also benefits you in that you can produce overall reports for your business.
#193
Lauren,
I am using Zapier as a workaround for a similar use case – you can see the details at Display Record URL as field autmatically.
Essentially, I have a multistep Zap watching each table in a base. When a new record is created, Zapier grabs the record name and URL and stashes it in a table I call “Log Registry.” A view on that table filters on the date, giving me a daily task list.
It’s not elegant, and I would prefer not having to use Zapier, but it works.
Jack
#196
+1 for this. I love everything about airtable and this could push it to a whole other level. It could instantly sort out the granular permissions request that gets thrown around so much and could instantly make more complicated bases much easier to manage.
I am currently building multiple rosters for different companies which really need to sit in their own base, but it would be great for them to be able to draw information from common bases.
#197
I keep coming back regularly to the forum, hoping to finally find this thread closed by a glorious final post proudly announcing the much anticipated rollout of this feature or the granular access permissions.
You may say I´m a dreamer…
#198
Hello! To chime in on your Suggestion #3, I do feel claustrophobic with the number of tables, only in that it is unorganized! It almost makes me want to create separate tables, but I don’t have time to continually re-paste all my information, so I’d rather just dive very deep into customized views of a massive data network.
However, I would most prefer to interact with my tables in a better view than a cramped scrolling horizontal. Honestly, that interface reminds me of the anxiety of having too many tabs open at once. A good file management system, like that of the metaphorical desktop layout, does not blockade you from deeper levels of organization. Have you ever been in a folder for files that fit together, have it become stuffed to the brim to the point that you feel anxiety over your inability to create further categories
I think this connects back to the whole idea that everything can be broken down into simpler categories, like somewhere from 5 to 7 or 12.
To touch on Suggestion #2, we can’t deny how powerful a reporting feature would be! This could easily morph into the backbone of many an organization, and they would find it breathtaking if we could deliver pivot chart equivalents to them, based on the data. I already plan to use AirTable “currency” fields with budget, spending, pricing, payment, and so on-- the ability to also view the pulse of our business would be extremely impactful in organization-wide adoption.
I am so grateful for this app, though! Definitely rendered many of my old go-tos obselete. I would love to someday see the option to slide the table tabs from the top to the left, and allow some metaphorical equivalent higher in the hierarchy than a Base. Similar to onenote organization, but powerful in a very different open way (they’re a beautiful infinite notebook/planning and brainstorming tool, while you all organize my everything else).
I just feel frustrated having the equivalent of multiple scroll-throughs of small tabs that I can order next to their similar categories, but cannot tag or filter or connect in any way. For instance, different departments, roles, and tasks require different references and data or input. A way to somehow tie them together in themes would be wonderful.
Thanks again!
#199
Yes! Linking bases is the #1 reason we likely won’t stick with Airtable long term. As we work on multiple projects, and each project being a base, we have no way to see an overview of all of our projects in any succinct way. If we can link data from bases, then we could have a single base that is an aggregate of various aspects from each individual project-base allowing us to see a cross section of data much more efficiently. This would help immensely. Thanks!
#200
Great to read that there is being worked on the feature to enable inter linkages between bases. That would for us be hurdle to overcome before purchasing a company’s license and start investing on importing all our organisations information and training our team on working with it.
However, since it is not the case, there is no point in doing so. Unless we would know that the interlinking will be enabled in let’s say now and half a year time? Until then we could keep our records up-to-date manually, but then it really needs to get going…
Any idea on when the feature might be operational @Airtable?
Thanks,
D
#201
@Airtable , this is the most popular thread, and the most requested feature.
It would be very much appreciated if you can tell us what’s the plan / time frame.
Thank you
#202
I’m going to +1 this comment. I have five distinct bases with different consultants having access to different bases. Because I have tasks listed in different bases, my primary interest at this point is the ability to pull in all my tasks and organize them by date as a way to make sure I’m keeping all my plates spinning and not wasting valuable consultant $$.
Combining everything into a single table makes no sense for me, as one of my bases is for writing books; I have another for interviews/podcasts; another for general marketing; and a last for other administrative details. These are different teams (so permissions issue), but even if I was OK with everyone seeing everything it is simply overwhelming and confusing to try to connect it all in a single base.
#203
@Katherine_Duh @Air_Table This is a must have feature for what we would like to use Airtable for. Any idea when this will be ready to go? I see there have been lots of requests for this feature and no response from your team.
#204
+1, this is one of the first things I looked for as a new Airtable user. Overall I find Airtable a truly amazing product, hopefully since it’s been 3 years it’s close to completion just as I’ve signed up :smile:.
#205
@Airtable_Team, @Airtable_Support , come on guys, it’s been over two long, long years now. Just tell us either a: we are working on it and include a time frame or b: sorry folks, just too complicated, we realise we have created a monster and don’t quite know what to do with it, so we are shying right away from this but we haven’t had the gumption to let our customers down. Please, just tell us!
#206
+1 as well! please let us know if this is planned!
#208
It would be a clever feature
#209
hopefully this will come in 2018
#210
@Katherine_Duh From reading all the comments left in the past 2 years it definitely seems like linking tables to another base is an extremely in demand feature. I would like to have a master list of clients that will be accessible from each of my bases. The main reason would be that I would not have to copy and paste an updated table into each of my bases every time there is a change.
At this point I’m using 217 records (and growing daily) in each of my bases for client information. I really only need this data in one place and need to be able to link each base to it instead of taking about the amount of space I’m currently using.
#211
Anna_Moers, you are correct. This feature is very much needed.
I hope that we can hear from AirTable about their plans.
#212
I recently started using Airtable and I find immense productivity within. That said, There is a glaring set of issues that perhaps, either I do not know how to use a certain function eliminating this problem or it is an essential necessity missing from Airtable.
I am using Airtable to manage all of our books and publication releases for my publishing house.
I have a table that has all of our authors and another which has all of our books.
To use these tables in other bases, such as to devise pre-release information, launches, event marketing, etc. I need to export both of those tables (Authors and Books) into each of the above. Essentially, recreating the same tables numerous times. However. In the new bases where I would naturally use the linked records, I have to use a different column because the initial column will not allow me to link to another record…???
It would be a vast improvement if I could simply link to any record from any of the bases in my workspace. Simply adding “Link to record in a different Base” or even the possibility of linking to a record from a base on a completely different workspace, altogether. And for these pieces of information to properly link and update as the originating tables are updated.
I can do this in Excel. by simply typing = and then clicking on a different document and then the tab and cell I wish to use.
Because here, in airtable, I would have to constantly export and import to update those entries. They don’t seem to update or relationally update as new information is created in one.
For example. I have in my Authors table the author, the name of the book they are working on, which is linked to the book table. I have an initial manuscript deadline, final deadline, and planned publication release date. For various books, this information has not yet been added.
So If I export the book table to a launch calendar base to have it linked so I do not need to recreate the listing of books and their associated pieces of information. I have to export and import it again whenever the original table in the print editorial calendar is up-to-date, as it is a living file that changes constantly.
Essentially, forcing me to erase the existing table in the launch base and setting it up again.
This feels like a huge gap in how this should work.
I simply want to expand my bases for various purposes and want to be able to link to the main source of information that is going to be used relationally in other bases for various other purposes.
Perhaps I’m missing how this is doable in Airtable? Any help would be appreciated.
