Looking to connect with an Airtable Expert to help with setting up a new Base
1103 0
David_Walters
Morning, I am a small business owner. I am looking to create a new base in Airtable concerning our daily petty cash. Would be interested to see if I can connect with an Airtable expert to see if what I want is possible and what would be the costs.
I would like to use this base to address the following needs:
  • Use the data entry table as a log which I then import into QB. (We don’t require help with the import as we are currently using Zed Axis).
  • Provide management with visibility to key relationships derived from the data entry table. (Management is on Airtable).
  • Provide management with a summary that contains linked records to “drill down” on an expense as needed.
0 Replies 0
