Lookup NonLinked Primary Column
Topic Labels: Base design
902 1
Pixel_Designs
I have a table (let’s call it table1) that has a primary column called table1_id
I then have another table (let’s call it table2) that has a column which is a link to that table1_id value.
I then have another table (let’s call it table3) that has a column which is a link to that table1_id value.
How do I create a column in table1 that looks-up a value from table2 based on the row that table1_id is linked in. I feel like I need to do a lookup, but I can only do that on linked Values.
Welcome to the community, @Pixel_Designs!
Be sure that you are showing all of your fields in table 1 (i.e. no hidden fields).
When you create a link to table 1 from your other tables, Airtable will automatically create a reverse linked records field in table 1.
Use this reverse linked records field to create your lookup values.
