Map with Images for pins / markers?
1102 1
Justin_Collins
Is there a way for me to use images for each location for the map pins when using the map block?
Moe
10 - Mercury
10 - Mercury
You can use this extension to extract the location of each image then you can display them with the map block.
Extract Location Data from Airtable Images
