Maps Block Settings and results does not show for me (Creator) but does show Owner
Topic Labels: Extensions
948 2
David_McDonald
Someone else on the team created a Dashboard using the Maps blocks. I am a Creator in the AirTable and anytime I go in, I do not get a map or settings. The Owner sees the Settings and map just fine.
Any ideas as to what the issue is?
Here is what they see: 2020-08-31 16_53_57-Zoom Meeting
Here is what I see: 2020-08-31 17_18_02-Screenshot
David_McDonald
Thanks Scott. I did write support and they came up with it quickly. It was a little bit of a PBKAC issue, too. :slightly_smiling_face:
The browser tabs I tried them on had been opened for awhile. When I opened a new browser tab, it worked in the new browser tab.
You might need to email support@airtable.com about this one. Be sure to post back here with what the answer is!
David_McDonald
