Markdown Images in Scripting Block!?
6482 3
Martin_Kranz
Been trying to wrap my head around how to display record attachments (images) in the markdown output of the scripting app. I heard rumours that’s possible :slightly_smiling_face: but haven’t seen any code snippets that seemed to be working []!($URL) produces errors asking for a function called
Any hints?
Erin_OHern
Hi @Martin_Kranz ,
Here’s the syntax for rendering images with Markdown – you’ll want to put the exclamation before the square brackets, and then it should work!
Here’s an example for the scripting app:
let attachmentURL = record.getCellValue('Attachments')[0].url;
output.markdown(`![](${attachmentURL})`)
Hope this helps!
3 Replies 3
Erin_OHern
Hi @Martin_Kranz ,
Hope this helps!
Sweet! Thanks Erin, helped a lot!
@Erin_OHern It’s working like charm, but is there any easy way to get to the thumbnail image ?
record.getCellValue('Attachments')[0].thumbnail.small.url
by any chance!?
