62917members
146337posts
Community Activity
Linking records on a form
Hi I was wondering if anyone would kindly help. I am creating a form from a grid view I have created. One of my fields in the grid view allows me to link with a master data base and pull all required info through using added lookups. This doesn't see...
  • 20 Views
  • 1 replies
  • 0 kudos
add +100 on each new row
Hey,Something super basic to do in any excel, python script etc. but how to get in in Airtable?I want to create some kind of ID for each customer. First customer has number 900100, and each new one (this is a child table) should get the number +100, ...
  • 21 Views
  • 0 kudos
Generate random hex color code
Hi Community!I would like generate with a formula a random hex color code for each new record in a database. How can I do that?Thank you for your help!Stefan
  • 9 Views
  • 0 kudos
Resolved! Duplicate button - Automation
Hello everyone,In an interface page I created an automation that is launched when I click on a button.The automation will allow me to duplicate a record.However, when this automation runs, I stay on the page of the record I've just duplicated.Is ther...
  • 33 Views
  • 0 kudos
Julien by 5 - Automation Enthusiast
Enable selection of multiple elements/records in Timeline view
What is the proposed idea/solution?It would be very useful to be able to select multiple records in timeline view. This would allow you to move multiple bookings at once, in the case of needing to adjust all bookings in a week/two week period by one ...
  • 11 Views
  • 0 kudos
Select multiple records in timeline view
It would be really useful to be able to select more than one record/element at a time in the Timeline view. It is not uncommon to want to move 10 days of bookings 'up' a day, and currently this can only be done in Gannt view (which is not available i...
  • 21 Views
  • 1 replies
  • 1 kudos
Sync one base to multiple bases
Hello,I have a client base that needs to be shared and synchronized with more than three different bases in a one-way sync (from the client table to all other bases without allowing any modifications to the client data from those other bases). I noti...
  • 39 Views
  • 0 kudos
Non-Admin user can only edit his records
Hello, On my Database  I have a table called "inventory".On my work spase i have two users, me as an admin and the second as an Editor user only.In the Inventory table i want that the second user will be able to create his own records and edit them, ...
  • 26 Views
  • 1 replies
  • 0 kudos
How to automate updating a record
Hello everyone, I have two tables: Pre-production and Production. I was able to make an automation so if I "approve" a project submitted through form to Pre-production table, a new record is created in Production with the same name and info. Now I wa...
  • 43 Views
  • 0 kudos
Form Builder - Public form won't submit
I'm using the new Form Builder to create a form to share publicly. I published the form, and created a link for "Anyone on the web."  However, if anyone tries to submit the form without being logged into AirTable, they get the following message, and ...
  • 34 Views
  • 0 kudos
Resolved! Number separators formula
Looking for some help regarding a formula. Here's a little context of what I am trying to do. I am working on importing my teams marketing budget plans into Airtable, and so far everything is working well. As a final step, and in order to avoid have ...
  • 61 Views
  • 0 kudos
Recovering lost data after importing bases
Hi everyone! I was wondering if it's possible to recover lost data after importing bases. When I copied and imported a whole table to a new blank one, some of the data was imported, but some other was lost and I have blank fields now. Namely; the att...
  • 23 Views
  • 1 replies
  • 0 kudos
multi-dimensional question
What is the proposed idea/solution?Allow questions on forms that are multi-dimensional, like this https://community.airtable.com/t5/other-questions/multiple-choice-grid-on-forms/td-p/81080How does is solve the user problems?This will prevent fatigue ...
  • 27 Views
  • 0 kudos
Create links
Hello.I have a cell that we input text and then in another cell that text in converted to an urlIF({LINK}=BLANK(),"","https://example.com/"&{LINK})Ex:CN-349302 -------->  https://example.com/CN-349302  But what kind of formula can I create to convert...
  • 39 Views
  • 1 replies
  • 0 kudos
Resolved! Automation only works for one record
Hi, I am trying to automate a process whereby if a record in one table is not empty, it will automatically create a duplicate record in a different table, filling in some select fields.To be specific:I have a table called tasks. It has a URL field ca...
  • 45 Views
  • 0 kudos
AirTable + Typeform
HelloI have a typeform with 50+ questions. When I am mapping it to AirTable, I am required to map it field by field - which requires me to go into AirTable and create a header for each individual question. This seems quite cumbersome, is there a fast...
  • 46 Views
  • 0 kudos
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
Introducing Pivot Tables in Interfaces
Hi there! I’m Rosalind – a product marketing manager at Airtable focused on helping teams build powerful, custom applications that make work more efficient. I’m eager to share that we have just launch...
Announcements
