Missing base/Base History
554 1
Charles_Diego-R
Has anyone had issues with a base dissapearing?? I have a base that is suddenly not available anymore. Is there a history feature where you can see if a base has been deleted accidentally, and is there any way of recovering that base?
Hi @Charles_Diego-Roll and welcome to the community!
On your Airtable homepage (with all your workspaces and bases) you have a “trash” option (it’s to the left, below the list of all your workspaces). There you can see deleted items from the past 7 days). It also contains some useful links to help pages concerning backups, trash, …
