Mobile optimized View for airtable view
1242 4
Onference_Train
Hi, we are an event organizer start up firm based in India, our core work profile is creating event program and updating same on website. With airtable we came across the possibility to embed data(program) to website directly in a reactive way. However, from past few weeks we are constantly struggling to create a mobile optimized website with iframe code generated for airtable view. The problem is that when we try to embed card layout for grid view(which is strict preference) with 5-6 field values, the program on mobile shows only 4 field values and to view other we need to expand record which isn’t user optimized, so requesting the community to kindly help us with some valuale inputs.
thanks in advance
4 Replies 4
Unfortunately, Airtable doesn’t offer any native solutions for this. You would need to pay for external services to help you accomplish this. Two services off the top of my head are MiniExtensions.com and Softr.io, but there are others as well.
Mario_Araujo
Here are a couple of examples of a Softr website and app on a mobile device. It’s responsive and it generally just works. If you have your base setup, creating the first version of it, will take you less than what it took me to write this post :slightly_smiling_face:
Screenshot 2022-02-15 at 18.02.50
IMG_B4B32A71451C-1
Thanks @ScottWorld for your kind and quick response. It is helpful, shall explore the potential.
Thanks @Mario_Araujo for the kind reference. It is helpful, shall explore the potential.
