Multi-select field to work in Formnano
796 2
Miles_Meyrow
Has anyone gotten multi-select field to work in Formnano. My airtable field is multi-select, when I set the formnano field to multi-select I get an error #422. I also have no way to populate the field options in formnano.
Ezeh_Uche
Check out Beenform. It supports multi-select field.
Moe
10 - Mercury
10 - Mercury
This extension that we’ve made allows you to update existing records using Airtable form. Since you’ll be using Airtable’s official form, all field types are supported and auto-populated. Including multi-select fields, linked records, etc.
