My long texts are cut and display "..."
Hello everyone. (please excuse me for my English, I use Google Translate)
I am in the process of making a small application to record my working hours with the Kodular site, and I am using an extension that allows me to use Airtable. Everything is going fine until I have to save some long text. It looks like this:
2100001 - Client1 02:00 task1
2100002 - Client2 04:00 task2
2100003 - Client3 03:00 task3
Etc … If I enter 3 lines like in this example, it saves the text correctly, but if I have more lines, then it cuts the text to me and it shows me “…” See for yourself with this screenshot:
Is there an option to check, set or anything so that I can have all of my text in full?
Thanks everyone!
Hi @Maxime_Bory and welcome to the community!
Just want to point out your screenshot is missing :slight_smile:
You screen shot is probably missing because you are new. The community requires that you be around/participate for a while before you can post photos.
You say that you are using an extension. What extension are you using?
