Need Calendar View from Function Column
#1
I was very excited when the calendar view was released because I track when items are received and due using airtable. I would like to be able to display the due dates for each item on a calendar, the problem is the ‘due date’ column is auto-populated using the ‘received’ column by adding a certain number of days. Even though the result is MM/DD/YYYY, the calendar view won’t recognize the ‘due date’ column as a valid field to display by.
It would be a great feature if the calendar could populate using a function column that outputs a date.
