Need help finding and editing form within Simple Applicant Tracker template
790 2
Aimee_Shea
I have set up a simple applicant tracker template with a form. The form is working, but I cannot find how to view or edit the form.
I made a short 2 part video overview.
Question Part I:
Question Part II:
Kamille_Parks
16 - Uranus
16 - Uranus
The left portion of your screen is the views panel. A form is a type of view. You are currently looking at “All applicants” which is a grid-type view. Scroll down on the left sidebar to see the form view.
Kamille_Parks
16 - Uranus
16 - Uranus
It’s always in the most obvious place!
:relaxed: Thank you!!
