Need help I want to automate adding multiple entries in attachments column
764 0
Saurabh_Surve
I am trying to update AirTable row using integromat.
I want to add multiple PDFs as atttachments in a single column.
Only the last PDF gets saved.
Suggest a solution. Am I missing any step.
0 Replies 0
