I have one table where we collect all the facilities requirements from various departments.
I need the output like for each facility item what is the total count
How to do that with scripting
Can someone help me
Regards
Sridhamasakha Dasa
Can someone help me
Regards
Sridhamasakha Dasa
Um, can’t you set a Group By on facilities requirements and then see all the counts?
If you had a way to tabulate the counts in a Script Block, what then? Post them to a new summation table? If this is you plan, I believe you can create a roll-up to achieve the same outcome and all without script.
Thoughts?
